NPSH available
NPSH available
NPSH available
Hello,could you give me any advice??
underground supply tank
fluid:ethyl ether.
Flow: 7 m3/h
Tª= 20ºC
T vapor@ 20ºc= 587  mbar
density @20ºC= 0.7347 kg/dm3
suction static height=1 mts
suction pipe diameter= 37 mm
suction pipe length=5 m
atmospheric pressure= 920 mbar
estimated pipe losses = 2.14 mts
altitude= 920 mts above sea level
The NPsha value calcualted is :
NPsha=2.02 m
NPsh required by pump for this flow is 2 mts
But i have to subract the altitude correction factor to the NPsh.
how can i get these value.??
I have to subtract a 1mm de hg per 1000 feets??
is ok??
How can make higher this npsh available.??
one way is getting colder the liquid to reduce its T vapor value.
is there any more....
RE: NPSH available
Your atmospheric head is 30.4 feet.
Your 37mm suction pipe is too small.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
