SMOKE DETETOR IN GENERATOR ENCLOSURE
Is it required to install smoke or heat detectors in outdoor soundproof generator enclosure? The generator will be located on building roof.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: SMOKE DETETOR IN GENERATOR ENCLOSURE
Bill
"Why not the best?"
Jimmy Carter
As for smoke detector - I'd advise against it - heat detectors are good as mentioned.
But I don't know about applicable fire codes that could require it. The local AHJ and fire marshal will have the last word - as usual.
"An 'expert' is someone who has made every possible mistake in a very narrow field of study." -- Edward Teller
As others mentioned your other issues of fuel storage and piping, etc..., might outweigh this issue.
It also says a fire risk evaluation shall be performed to assess whether a fire detection system is required.
