Scenes not showing in SW2009
so i got upgraded on friday and the scenes are not showing up.  the install was done by IT remotely and i had no control over what they did.
has anyone gone through this?
SW2008 Office Pro SP4.0
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
RE: Scenes not showing in SW2009
Try Tools> Options> System Options> Colours and then select "Use document scene background" radio button.
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2009x64 SP2.1 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2009x32 SP1.1 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.11.7751
I just checked and "Use document scene background" radio button is already enabled.  however, no scenes are displayed when selected.
SW2009 Office Pro SP2.1
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
First thing I'd do is check my video card drivers.  I seem to remember a similar problem with my initial upgrade, and I had to delete the SW folder from my registry in order to clear it up.
Dan
www.eltronresearch.com
Dan's Blog
It works for me OK, although I can't yet get it not to present me with a shiny floor and reflections avery time I open a file!  I use a gradient background and it was OK until SP2.1 or else I didn't notice it! Realview on or off makes no difference to the way the scene works. However, as these scenes are related to PhotoWorks, is that installed on your machine and is it enabled under Tools> Add-ins. Although, I would have thought it must be or else you probably wouldn't have the "Apply scene" dropdown, or it would be empty!
