Job submitted but it never runs. (using CAE or Python)
Hi all,
Since I run Abaqus from Linux, I have the following problem : my job is submitted but it never runs. Apparently CAE writes the .inp file and then I can run the job from the X :
abaqus job = 'my Job'
Normally I thought I should just submit my Job in CAE and get back the result...
Maybe the routine in Abaqus has the wrong path when I submit the job. Maybe it's possible to change this path but which file do I have to modify ?
Thanks for your help.
RE: Job submitted but it never runs. (using CAE or Python)
corus
Actually this is what I'm trying to do from CAE : from the Job Module I click on submit, and my_Job is submitted. At this point the PC does nothing else, no error message, no freezing, no calculus...
My_Job is just wrote in my folder (my_Job.inp), and CAE is still prompting "my_Job has been submitted...".
For having the file my_Job.odb, I have to write the following expression in a X-terminal : abaqus job=my_Job.
Yes it creates a .log file which apparently record an error. How could I fix it ?
Abaqus JOB debuguage
Abaqus Version 6.8-2
Socket error: (-2, 'Name or service not known')
Begin Analysis Input File Processor
Wed Mar 25 11:14:41 2009
Run pre.exe
Abaqus Error: The executable /opt/abaqus68/6.8-2/exec/pre.exe
aborted with system error "Abnormal termination signal" (signal 6).
Please check the .dat, .msg, and .sta files for error messages if the files
exist. If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information. Use the same command to run Abaqus that you
used when the problem occurred. Please contact your local Abaqus support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
Abaqus/Analysis exited with errors
