Barrier Fluid FDA low temp
Hi There
Are any of you guys using an FDA compliant barrier fluid that can run at between -100C and +150C?
Currently a Dow product called Sylterm XLT is being used. This is very hard to get hold of so we are looking for an alternative.
Do you have any suggestions?
Many THanks
S
Many THanks
S
RE: Barrier Fluid FDA low temp
Hope it can help you!
Mario Souza
Application & Product Engineering
WMF Solutions Brazil
http://www.wmfsolutions.com
I think it will have to be Royal Purple although their lowest temperature limit is -65C. I am currently waiting for viscosity data from the supplier.
S
Mario Souza
