Rapair without "R" Stamp
Can anybody repair pressure vessel without having "R" Stamp? Data report is already submitted to National Board and vessel returned to Manufacturer for repair?
Pls. guide me.
RE: Rapair without "R" Stamp
BPVN;
Some states in the US do not regulate pressure vessels. If the object is installed in a Jurisdiction that regulates boilers and pressure vessels you must have an R-Certificate from the National Board to weld repair the vessel. Mechanical repairs to a vessel can be performed, in some cases, without an R-Certificate. Contact your local Jurisdiction where the object is installed for the most complete and accurate information.
Also per API 510, The repair organization must have and 'R' Certificate.
If a vacuum stiffener ring is interrupted by a nozzle on a cylindrical portion of vessel, how do we ensure that it has adequate moment of inertia to replace the cut ring? Is this allowed by code?
J. R. Polani,
Houston.
polani82342, please ask a new question.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Any body with a "r" stamp
some jurisdictions will allow the mfr to repair their mfd product,
ask your inspector and supervisor AI
