plane view when starting sketch (beginners question)
Hi to you all,
I am using SW 2008
When creating a new part,i have to select the plane to start the sketch.
Sometimes if i select the plane to make the sketch,it turns to me, but upside down.
I find this not very practical.
My question: Do i need to change some setting ?
Sometimes when i use the "Normal To" button (in general use) it's view is mirrored, but when i click the "Normal To" again it turs in the good position, Could this be related ?
Just start using SW 2008, i can remember having this in SW 2007.
thanks,
Tomme
I am using SW 2008
thanks,
Tomme
RE: plane view when starting sketch (beginners question)
Thanks for your reply,
I have followed your instructions, as i did before when i checked the help files.
But i dont see any color in my planes.
Do i miss something?
I have added some screen pictures to show you
1: plane color (for front face)
2: plane color 2 (for backface)
3: SW help file
4: My part
i hope upload of my files worked!!
thanks,
Tomme
ht
http
htt
tomme
Thanks for your time & knowledge
tomme
Are you using a SW approved video card and driver?
CorBlimeyLimey
I don't know it's an NVIDIA GeForce 8600 GT (512 MB)
I do know it's support open GL
tomme
Sorry for asking so many questions,
I am trying to create a part, but want to do it from a machinist view.
Z-axes pointing up
But when I start sketch on the top plane, my Z-axes is not pointing up.
Do you know how i can set the Z-axes up and my top plane connected to the Z-axes?
tomme
Is there an nVidia setting to run the card under OpenGL?
Have you tried using the Tools > Options > System Options > Performance > Use software OpenGL setting?
I'm betting the problem is VC/driver related. Do you have access to an approved card?
Please start a new thread for new questions. It makes it easier for future searches and referencing.
The axes question has been discussed here often.
thread559-172855: Solidworks to Mastercam
thread559-110857: Making SolidWorks views like I see a part on my CNC machine
and at http://forum.solidworks.com/
forum/messageview.cfm?catid=8&threadid=15130&highlight_key=y&keyword1=re-orient axes
Yes settings are set to use software OpenGL
tomme
You are correct to attend me to start a new thread for new questions.
Sorry about that, was not thinking clearly,
Thanks for the link ,unfortunually, my graphic card is not in the comparison list.
So i think I will not be able to Soft-Mod my card.
But thanks to your link, I now know where to look for!!
http://yarchive.net/metal/axis_naming.html
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
I think what you want is to use the Modify Sketch tool
Tools > Sketch Tools > Modify Sketch this will give you the option of entering 180 as sketch rotation angle so Z-Axis is pointing up. You will see a dialog box for this but you can also right click the balls on X or Y direction of sketch to reverse direction or the ball touching both to flip both which will give a 180 rotation about sketch origin.
Flip Direction or View Normal will swap from a
Front & Back view for planes // to Front plane
Right & Left view for planes // to Right plane
Top & Bottom view for planes // to Top plane
this is why your Z axis points up when viewing from opposite direction. The xy of sketch little & big red arrow respectively is the default view shown first when choosing Normal view icon
Michael
It has always done this for me, as far back as 2004. My co-workers are constantly modeling things upside down because they don't notice this.
Joe
SW Office 2008 SP5.0
P4 3.0Ghz 3GB
ATI FireGL X1
