unhinde CommandManager
Ok, some how I managed to hide the command manager and I can't bring it back up. No the options>customize>enable commandmanager wont work. If you make a toolbar float, and you right click on it there's two options, move or hide. I must of hit the hide one and now I can't find it anywhere. Anyone know how to bring it back?
RE: unhinde CommandManager
'works for me'
Hardie "Crashj" Johnson
SW 2008 SP4
Nvidia Quadro FX 1000
AMD Athalon 1.8 GHz 2 Gig RAM
If all else fails try resetting the registry.
F9 clears the featue manager. F10 clears the command manager and all other toolbars. F11 clears the window.
rfus.
If you want I'd suggest saving your current settings with the Copy Settings wizard to retain your keyboard Shortcuts and System options and then Use Restore default settings so it will remain attached at the top of your display area.
Michael
