Solid Edge
Solid Edge
Solid Edge
Using the Move Part command in an assembly with linkages, etc., is there a way to have the movement stop when interference is encountered?
RE: Solid Edge
CorBlimeyLImey is right to send you to the UGS solid edge forum.
To answer your question: Yes you can there is an option for this in the properties of the move part command. It should be on the far left of the ribbon bar.
Hope it helps.
Patrick
