Flush groove welds
Flush groove welds
WELD PROFILES
• AWS D1.1 sec 5.24.4 Groove or Butt Welds, states groove welds shall be
made with a minimum face reinforcement .................
• AWS D1.1 sec 5.24.4.1 Flush Surfaces, states "butt welds required to be flush shall be finished so as to not reduce the thicknesses of the thinner base metal by...................
• Question; if the requirement is to have a flush weld, should a reinforcement weld be applied and then dressed off flush, or should the groove be welded flush?
• I have always gone with the theory that the cap acts as an annealing process so applied the cap then dressed flush
• Can any of you guys out there give me any guidance on this?
RE: Flush groove welds
I have had this discussion with several in the past, and even with cap grinding, there is still a small portion of the HAZ which does not get tempered unless a temper bead type technique is used.
There are lots of things to consider. Especially the material type, service conditions, and the amount of grinding. In general, it's a good practice, but you don't want to be counter-productive either (manually grinding 200' of weld).
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
However for some common sense do's not prevail and as AWS D1.5 is not a code I'm working with, I'm still left with the controlling code of AWS D1.1
Hg
