Test waveform
Test waveform
Test waveform
Hello everybody,
I have to make a shock test, the specification says:
Maximum absolute acceleration 10 g´s
Maximum spectral velocity 1.3 m/s
Maximum relative displacement 20 milimeters
Does anyone know how to generate a test waveform that fullfil this requirements?
Thank you
RE: Test waveform
What are you testing?
peace
Fe
RE: Test waveform
Is a box with inner electronics devices. Weight about 15 kgrs. Dimensions 500x300x300.
RE: Test waveform
What does it mean by spectral velocity?
I wouldn't be amazed if a half sine displacement with a 20mm amplitude and an appropriate duration worked.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
RE: Test waveform
Thank you Greg,
I have been looking for information and I have find tha it could be the datum for a "tripartite papper" or four coordinate papper, but I don´t know how generate a waveform (excitation) which I can manage to the shaker, and which fulfill the requirements. If it could be a half sine, how could I calculate it?
RE: Test waveform
Until you can define spectral velocity you can't do it.
You just need to integrate your acceleration waveform once to get velocity, and again to get displacement.
Cheers
Greg Locock
