Anti-roll bar material
I have an anti-roll bar with an effective length of 9 inches made from 0.625 x 0.058 4130 heat treated to RC33-35. Does anyone know of a steel alloy, given the same OD will be 20 to 40 percent softer in torsion? Using a smaller tube diameter is not an option.
John
John
RE: Anti-roll bar material
Changing steel grade and / or temper will I think only change the elastic limit, not stiffness (at least not to any significant degree). I think you'll find that to decrease stiffness while maintaining OD, you'll need to reduce wall thickness (or increase the length of the torsional section of the ARB, or the lever arms?).
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
John
Mike Halloran
Pembroke Pines, FL, USA
-b
I think you need to do something with the arms to make them provide the requisite flexibility in bending. That does assume that you can build up your own bar from separate pieces.
Norm
Cheers
I don't know anything but the people that do.
Best regards to all!
John
