Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I signed up to your site to get help with a problem and I am so glad I did. I found the help I needed immediately. Thanks to all who contribute to your site..."
Geography
rnjroles (Civil/Environmental)
12 Mar 09 10:10
Hello all -
I'm using ACAD Civil 3D Land Desktop Compainion 2008. I've got some raster images in the background that won't print although they appear in the print previews.  All of the other cad work prints out fine - but no image.
Any suggestions?
ProDraftsman (Civil/Environmental)
12 Mar 09 11:20
Well a couple of things might be wrong.  They layer that the images are on might be set to "not print" so check that first.  Now the more likely cause is the file size is too big.  If the file size is too big try setting in your print properties to "print from computer" and then send it to the plotter.  Unload all the images that you are not using for the plot as well.  If your trying to plot from regular size say 36x48 to 11x17 to just a copier it will not work if the file size is too big.  In that case just send the 11x17 to a plotter.  Also try clipping the images it reduces the size.
Exxit (Computer)
12 Mar 09 12:37
Did you insert the images into the paper space?
ADT 2004
OZZY84 (Civil/Environmental)
12 Mar 09 14:48
First, make sure your printer supports raster printing.
If you have successfully printed other drawings with raster, then it does.
Just didn't want you pulling hair out without checking basics.
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
Autocad 2008
chicopee (Mechanical)
12 Mar 09 20:35
Is it possible that the drawing can not find the raster image file?
youngEIT (Civil/Environmental)
13 Mar 09 18:44
i think its running out of memory.in the plot window, click on printer "properties" radio button, then click on CUSTOM PROPERTIES, go to IMAGE tab, and reduce the print file resolution dpi, it should plot then. hope this helps!
Close Box
Join Eng-Tips® Today!
Join Us             Close
