What controls dimension behavior (NX5 drafting)
I'm new to NX5 drafting. I am working on a part I did not create, and am adding dimensions to a drafting view. All of the linear dimensions I create automatically center themselves between the leaders and cannot be moved. I want to be able to freely place the dimension. Which of the gazillion preference options control this behavior?
RE: What controls dimension behavior (NX5 drafting)
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
To make new dimensions you add moveable go to Preferences -> Annotation and go through the same procedure as above (pick the dimension tab and change the placement option).
