How to extract non-associative feature (NX 5)
I'm using NX5. Is there an easy way to extract a feature and use it as a new part? Every time I try it NX wants to make it associastive to the original part. I just want the geometry, not the history. I used to use I-DEAS, and it was trivial to do this.
RE: How to extract non-associative feature (NX 5)
copy from the original to the new part aross the clippboard
However what you can always do is to extract solids, sheets, points or curves from one part to another. Probably the easiest way is to wave link them and if you don't wish them to remain associative then break the links or remove parameters.
In a specific example we might be more instructive but this gives you the broad sense of it.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Michael
