Waterslide Steel
Waterslide Steel
I am working on a job where an existing wood platform with steel supports for a water slide (appx 32' tall) has severe corrosion of all the steel members used to support and connect the wood. The steel beams and columns are experiencing large amounts of section loss. The pool operator says it is from the chlorinated water that drips off the bodies of the people waiting, but also because when someone sits in the slide at the top the water jets will shoot the water at their back and it will reflect back and pour down over the platform.
The slide design is set, and we will have this problem with large amounts of chlorinated (or maybe it's bromine?) water pouring down the steel and wood. They will be replacing much of the platform and stairs. What is the best way to protect this steel and the steel fasteners in wood? Is galvanizing enough? Stainless steel or galvanized fasteners? Do we just have them prime and paint on regular intervals? Any suggestions?
RE: Waterslide Steel
what materials are the fastners currently made?
The fasteners now are steel. I can't tell if they were galvanized or not. Most of the rusted fasteners are lag screws.
Painted carbon steel is an option, although you will find that corrosion will still occur.
Galvanized carbon steel for the structural members and the fasteners is another easy and relatively inexpensive option, but will still exhibit corrosion over time.
The standard stainless steels are susceptible to chloride ion corrosion, so you need non-standard ones like duplex or superaustenitic grades to provide long-term service. These are available for sheet and fasteners, not at regular suppliers, rather for those that supply to the marine vessel/offshore oil/etc. industries.
Lastly, you could use titanium alloys, which are essentially immune to chloride ion corrosion, but are extremely costly.
Seeing
http://87
you would be worried about stress corrosion for the structural members if you used basic stainless steels
http://87
ht
Great reference, you deserve a star for that. Swimming pools do not "have the solution will be chlorine 1%-2% water with chloramines and chlorides at close to neutral water which is considerably worse than chloride laden water". The chlorine concentration is typically 1-3 mg/l in a pool and 3-5 mg/l in a spa. Chloramine is probably slightly higher and is formed from the reaction of ammonia (from human waste) and the chlorine.
Chloramine is the cause of burning eyes in pools and is also the cause of the corrosion. As stated in the article, chloramines deposit and accumulate. This deposition will be much higher than the concentration in the pool water.
The recommended materials from the article are the highly alloyed stainless steels 317LMn, 904L, and six-percent-molybdenum (Mo) super-austentic stainless steels along with duplex and super-duplex stainless steels such as 2205 and 2507.
A corrosion protection guide For steelwork in indoor swimming pool buildig
http
Category: Swimming Pools
http://www.bssa.org.uk/topics.php?sub_category=99
http://w
http://www
S
Corrosion Prevention & Corrosion Control
ACQ wood is a known and aggressive corrodent toward steel. Singly hot-dip galvanized components (nails, screws etc.) are eaten for lunch...
Direct imbedded fasteners like lag screws are going to need to be a decent grade of stainless steel (ie 316). You're not going to be making lag screws out of AL6XN or 904L, guys! There are coated fasteners that are rated by their manufacturers for ACQ wood service, but stainless fasteners should be more durable.
For the structural steel itself, a properly engineered adn applied coating system is going to be more cost effective than making the whole thing out of an alloy. Stay away from closed sections like HSS which might get wet from the inside and corrode outward. A zinc-rich undercoat would be a good idea, followed by a durable crosslinked topcoat (ie. a 2-part epoxy or polyurethane etc.). There are plenty of coating system options which will work if they are properly applied and maintained.
A star for you for bringing my attention to something I wouldn't have thought of otherwise!
Everyone else, thank you so much for all your help as well.
Using fiberglass where ever possible for braces and such would help you out a lot.
Plymouth Tube
If the steel section loss is not excessive, you could refurbish by cleaning up and applying a suitable coating system.
Replacing with stainless will be very expensive. I think the suggestion of the highly alloyed duplex grades is overkill for a water slide. This is not continuous immersion in sea water so 316 would probably be sufficient.
My suggestion is you need a suitable protective coating system for your steelwork. Exactly what that is depends on the required lifetime, maintenance procedures, aesthetics, application conditions, etc.
