Default corrosion rates for actively corroding carbon steel
I am having trouble finding any default corrosion rates to apply to equipment that was only inspected once for ACTIVELY CORRODING EQUIPMENT, (ex. process piping, pressure vessels, etc. with active corrosion/pitting). I this will not determine acurate life of the equipment, although I want a conservative approach without overkilling the life determination/next inspection. Even where to find it in the codes/standards would help. Thank you.
RE: Default corrosion rates for actively corroding carbon steel
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
S
Corrosion Prevention & Corrosion Control
