Auto file rename with solidworks and VB
I like to automate the renameing of solidworks files (numbers). I tried to do this with recorded "save as" code in VB but the references in solidworks drawings are then broken. Is there anny vb code with the "solidworks rename" type of rename?
Ronald
Ronald
RE: Auto file rename with solidworks and VB
The reference then updates, but you also have to do a drawing file save as . . .
Can the part file reference in the drawing file be changed with a VB program?? hmmm.
'thinks not = disappears'
Hardie "Crashj" Johnson
SW 2008 SP4
Nvidia Quadro FX 1000
AMD Athalon 1.8 GHz 2 Gig RAM
I also had to rename the drw file but i did this with windows rename...
Now i first open the part and after that the drawing an then save as for both... it works! So thanks a lot!
Ronald
