CAT 3516A footing drawing
We have purchased used caterpillar engines model 3516A. Now we have to prepare foundation for its installation. Can somebody provide its footing drawings as we have no related drawings/foundation details.
RE: CAT 3516A footing drawing
Mike Halloran
Pembroke Pines, FL, USA
On a used machine,- Can you have someone dependable measure the machine base for you?
I did the electrical hookup on one where the customer was responsible for the mechanical installation. The skid rails were about 8 inches wider than the foundation and they went ahead and put it on the foundation any way. That was a real balancing act.
Bill
"Why not the best?"
Jimmy Carter
http
I found some overall dimensions on a spec sheet at a Cat page:
http://ca
Thanks in advance.
Ask your local Cat dealer for the GERP (Gas Engine Rating Pro) CD, it has drawings (even 3D models of some engines) as well as all the info you'll need for designing your installation.
I have drawings but can not share them with you without Caterpillar's consent.
Here is a start this is for a genset, it gives dimensions at the bottom of the brochure. You can search the Cat site for other info.
http://www.cat.com
I guess Ivymike, had this idea first.
Image shown may not
reflect actual package.
Package Dimensions NOTE: For reference only -
Length 5808.6 mm 228.68 in do not use for
Width 2286.0 mm 90 in installation design. Please contact
Height 1435.0 mm 56.5 in your local dealer for exact
Weight 15 481 kg 34,130 lb weight and dimensions.
(General Dimension Drawing #2858792).
Bill
"Why not the best?"
Jimmy Carter
