How to avoid vortex?
What would be a practical way to avoid vortex formation at oil tank discharge other than restricting / decreasing discharge flow rate? This is anoperational problem we are facing when purging water ( 8 in purge pipe )from crude oil tanks.
Thank for help
Thank for help
RE: How to avoid vortex?
I found 66 questions related to vortexes /swirls, from the titles I couldnt find anything significant for further help.
Do you know if water purge of oil tanks is still mainly manually operated or is it automated in big companies? We are about to change a manually operated valve by a motor operated, and are having difficulties to incorporate operator's feeling (experience) in control set up.
TIA
DKF
