Current state of Model Based Definition
There have been several threads both here and in other forums on use of MBD (Model Based Dimensioning). When I'd previously looked at it I'd decided it would be more effort than it would be worth for most of our stuff, however, have implemented it on some castings and moldings.
We're being pushed to decrease development time cycles and my boss wants to look at MBD as a way of achieving this.
So how many people are doing MBD and have any major developments in this field come along since it was last discussed in depth?
I'm especially interested in those out side of the 'managed supply chain' of Aerospace/Defense and Automotive where it seems to have been achieved largely by the OEM's dictating what CAD system will be used and using their leverage to enforce this on their suppliers.
We are a smaller/independent player in the technology field who outsource all our machining etc. with only assembly done in house (even some of this is outsourced) and I'm wondering how other smaller players have dealt with it. Do you:
1. Only deal with suppliers with the same (or at least compatible) CAD/CAM system(s) so that tolerances etc. in the model are carried across?
2. Use a lightweight format and does it correctly handle MBD.?
3. Use hybrid drawing/model and if so how do you handle Tolerancing of features not explicitly defined on the drawing?
4. Have extensive "rules of use" in addition to/in place of the above or just rely on ASME Y14.41 or equivalent?
I have a copy of 14.41 and looked through it a while back but I'm not completely familiar with it.
thread1103-182896: Using 3D Model Geometry
thread730-184173: Are drawings needed anymore?
thread1103-182500: Detailing Complex Geometry
thread730-221206: I Hate Drawings!!!
Are all more or less relevant.
Thanks.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
Thanks.
KENAT,
RE: Current state of Model Based Definition
Additionally, any information that would've appeared on the drawings also now has to appear within the model itself. So, shortcutting the drawing step doesn't mean you get to not bother with all the information you would've included on the drawing. It just means all of that now needs to appear in the model.
With that said, ASME Y14.41 supposedly standardizes this effort. In my opinion (and yes I've read it and "own" a copy), it is drasically lacking right now.
If you do go MBD, just make sure everyone understands that the model is now the drawing and that means it will need to be as actually detailed as the drawing would've been.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
A: In my opinion, this is not practical unless you own your suppliers. The variety of packages and versions for each package increases each year. It is good to analyze what is common in your industry, but that's not the end of this.
A: Don't know. This sounds like this question is particular to one particular 3D CAD application.
A: My company does this. We still drive critically from the drawing, and use the model as the completion of the part definition. I've seen some companies callout a general profile tol based on the model for all surfaces not defined by the drawing. I've seen others simply use the model as part of the direct specification (model is not basic, but to be measured from directly with a previously established traditional tol)
A: Given my own opinion about Y14.41, I would suggest that your additional "rules of use" would have to be extentive indeed.
These are just my opinions...take them only as far as you can throw me. :)
Matt Lorono
Silicon Valley, CA
2?
3.We call out all critical dimensions with applicaple tolerances and GD&t. We attach the following Block to our Raw Material Drawings. See attached
There fortunately are well accepted neutral model formats (particularly popular are STEP and Parasolid), but they are "dumb" solids; i.e. no parametrics and no imbedded data. These are ok with CAM packages that look at the model surface, but don't consider the math behind the surfacing. This isn't the most efficient method when doing complex surfacing though, so a compatible CAM package that can use your native CAD model format is better in those situations.
From what I've seen so far, none of the CAM packages recognize the GD&T data whether annotated or imbedded into the model. That's probably because the CAD packages do a rather poor job of imbedding the GD&T into the model in the first place ... tried it ... don't like it.
What I've found works best under the situations I've been involved in is a hybrid system. Send the supplier a neutral format (Parasolid is my preference for comparatively simple geometries, but STEP works better with complex surfacing) to program their CAM packages with, and an annotated GD&T model file that they can read the annotations from. There are supposed to be some CMM packages out there that can read the imbedded GD&T data from the models of certain CAD packages, but I've not seen proof of this when challenged. What I've seen usually happen is that the GD&T is read from the print or model by a CMM pogrammer, then manually applied to the model again in the CMM software. Rather cumbersome, and prone to transcription errors.
Keep in mind that Y14.41 was written so that the CAD/CAM/CMM software developers could have a common starting point and set of functional requirements. Also, Y14.41 doesn't just apply to CAD data, but essentially defines PDM (product data management) structure and requirements. Now that Y14.5-2009 is released, the Y14.41 committee will be starting on the next revision. NOW is the time for anyone with comments & suggestions for Y14.41 to post them to ASME for consideration.
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
"and an annotated GD&T model file that they can read the annotations from"
What do you mean by this? Are you sending both a step/parasolid type 'dumb' model and a lightweight file type, something like JT, that supposedly carries across MBD annotation etc? Why not just the JT type file?
KENAT,
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
I've sent e-drawings with the GD&T annotations on the model, and SolidWorks files which can be viewed with a viewer program but can't be used otherwise without the SW program. I haven't tried a 3-D PDF, but I recall someone telling me that they'd had success with it for sending "dumb" annotated models.
I would send the native annotated CAD model if the supplier could use it directly, but they can't always.
I don't know if there is an "official" definition of MBD. I take it to mean that the model is the basis of the design rather than a print. As a result, the model can be used directly for manufacturing and inspection. Most of the automated (CNC) shops that I've dealt with have been switching over to model-based CAM and CMM programming; those shops range in size from two machine operators to several dozen or more. Manual shops often go back to generating a drawing themselves if they receive a model ... of course GD&T isn't usually much of a consideration for them anyway.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
On some programs, a separate file is used for CAM from the MBD file.
When a file is imported from another company that uses a different 3D CAD application, they have to follow certain guidelines and be pre-approved how those files are presented. I don't think they follow their own guidelines because I never had to be pre-approved in the past at other companies.
Chris
ctopher's blog
SolidWorks Legion
Did this pose configuration control issues?
How did the annotated model formats cope with 'set views' which my CAD system at least does with it MBD annotation? This is where 'views' are created in the model with certain annotation on them, snapping to the 'view' orients the model to that view & turns on the annotation in that view.
How do you deal with non dimensional notes & general tolerances?
KENAT,
No problems with configuration control as our manifestations (model, drawing, CAM, etc.) followed a master-model methodology; each reflected the model at that revision level. We actually found it easier to keep track of changes within the entire system because some software can track & ping changes on the master model to all subscribed users such as programming.
We didn't use set views in the model. From what I understand of the software, it's a selectable functionality that can be activated / deactivated as needed or preferred. Personally, I prefer to just rotate the model to see what's what. Per Y14.41, you are supposed to be able to activate and deactivate annotation planes also, so that you can remove the noise when you're looking for something.
In NX2 at least, we could imbed an overall surface profile as a general tolerance. Individual controls on featues overrode the general tolerance. We didn't have luck with the imbedded tolerances, so we went the annotation route instead, and put the general surface profile and all notes on designated (& named) annotation planes.
Note that imbedding and annotating are different beasts, and the two may not necessarily agree depending on how you do things.
It seems that if you're going to have to send 2 different file formats, one for the base geometry and one for the 'annotation' then why not just stick with the hybrid drawing model combo. This is what we've done on some castings/moldings and at least one complex machined part.
Given the way the MBD annotation is added separately to creating the model features and other factors it doesn't seem much if any extra effort to create the (partial) drawing. Also then all information is laid out in a single 'orientation' without needing to manipulate the model and can be sent in a format like PDF that is already in common use.
If you use some kind of 'unless otherwise stated' default tolerance, be it surface profile with model basic (what we did) or some kind of +- to then where you get benefit is in not having to add individual dimensions/tolerances to features covered by this tol and potentially hence not needing to create as many drawing views etc to be able to show these. This is a potentially massive benefit for complex surfaced features such as are fairly common in aerospace/defense & automotive or even commercial moldings/castings.
However, where's the benefit in many machined or even sheet metal parts? In many cases a single default tolerance that covers most features isn't practical.
Also will having a 'default' tolerance cause even less attention to be paid to Tolerancing than already happens with a typical title block tolerance?
Also, if you go the default surface profile route, while I don't believe it's backed up by the standard, many imply this as having increased inspection implications or somehow being more complex etc. – does it lead to higher cost? I know we have to be careful of this line of thought or we end up throwing out a lot of GD & T
Most of our stuff at present the drawing is the master, however we do routinely supply step or other 'dumb' models in addition (as reference) to the drawing to help with CAM/CNC programming.
My boss is thinking of making simple parts MBD only, but to me it's the complex parts that potentially benefit most from MBD.
Sorry for the long, in places rant like, post.
KENAT,
Valisys still may not work as intended with NX; we had it in the budget when a new QA manager was hired. They decided not to spend the money on it, and have me compare point clouds to models to verify their data instead. ;-( The demo was quite impressive, though.
KENAT,
I think it will be awhile before MBD really takes off and meets its full potential. In the meantime, we do as many and use the hybrid method, only we state that the model is the master instead of the drawing. Most of out parts are created from lofted surfaces, and those are the features we usually consider most important. We currently send out neutral model files and jpegs, though are looking into using "lightweight" files in the future. It's like herding cats though to get a concensus around here.
The config control issues on the 'jpegs' scares me, again I'd rather have a partial drawing.
Maybe I was unclear, on the few items we have used MBD we make the model the master where applicable. It's on the parts where the drawing is complete but we send a step for info that the model is 'reference only'.
KENAT,
It seems as if you have had a fair amount of input as to how to handle the MBD. I might add that we use the hybrid method for the most part as you have proposed. The model is sent in "STEP" format along with PDF of a partial drawing. The drawing is used to dimension all holes and any exceptions to our general profile of a surface note. In addition all datums are defined on the drawing. As others have mentioned, attempts to imbed the GD&T into the model has presented more problems at this time than it is worth.
Even if the part is a simple machining or formed part, a partial drawing is useful for hole callouts and datum definition.
DesignBiz![[stpatrick2] stpatrick2](https://www.tipmaster.com/images/stpatrick2.gif)
"Quality is in the details"
I spent some time last night looking at ASME Y14.41-2003 and it does seem like much (most?) of it is more about setting the standard for what the CAD packages should be able to do than with what the individiual designer should be doing.
I don't think our current primary CAD system does anywhere near all of the stuff it requires, though I'm not overly familiar with it's capabilities.
KENAT,
If I understand the standard, then in many cases if you 'query' a FCF in the model, then the surface or feature it applies to is meant to 'hi-light' and vice versa. I don't think it does this and there were a few other things I wasnt sure about.
KENAT,
http://www.fcsuper.com/swblog/?p=175
KENAT,
Matt Lorono
Silicon Valley, CA
On the bright side, both my boss and his boss seem to have realized we'd probably need some kind of PLM/PDM.
On the bad side my boss is already talking to potential vendors without seeming to know what MBD really means.
KENAT,
Matt Lorono
Silicon Valley, CA
By the way, your blog came up as the first result when I googled solidworks MBD. Good as it is I was a bit surprised there wasn't more from SW themselves.
KENAT,
Of course, that went over like a lead brick when the CAD administrator (me) heard about it. We still don't have a PDM system in place, though it is supposed to be in the 2010 budget. This, after it had already been in the budget for 2007 and 2008. Go figure...
At least make sure that your boss understands what is required to control relational databases before he signs off on anything.
We spent a bunch of time looking at PDM/PLM in 05-07 and got no where. An aborted 'INSIGHT' implementation, which is a 'free' SE PDM that piggy backs on sharepoint, took place in late 05. We spent much of 06 looking at what it would take to make that work or what other options were needed. We then looked more generally at what our requirement was etc but that went real slow and we got told to pick our best guess. Picked Teamcenter, got a quote etc. and then got told we had no money for it at end of 07.
(How'd I get a star on my own question?)
KENAT,
By a program that can handle "relational databases" I am refering to one that, when a part file is changed, it knows enough to report all of the files that the change affects.
KENAT,
TeamCenter is out choice so far as well.
We design tooling mostly for the automotive industry, complex press tooling and moulds and have been working almost exclusively with only 3D models for a good few years. We operate a mid priced CAD/CAM system design for this market and so do most of our customers.
This type of work is fairly unique in two ways. Firstly all of our customers do their own manufacturing and understand what they are manufacturing and secondly whilst there are many complex surfaces only key areas are really tied up, for example guide pillars to guide bushes, punches to dies, dowel pins etc. Within our software there is a feature recognition system so you can apply tolerance and fit to certain items and this is recognised at the CAM stage, whilst this works well for this type of work it might not for other types.
Other "get arounds" include the use of face colour to denote certain operations or fudging sizes to denote certain criteria, the list is too long to try and explain on here. So I guess from your original post this would fall in the extensive rules of use category.
This does have plusses and minuses, you need to work very closely with chosen suppliers and have a very good working relationship with them, but it allows huge savings in terms of time and cost in getting to the market place and makes both parties "valuable" to each other.
If your bosses want to just throw quotes around the world and quote standard blah blah and pick up the cheapest, I would say they are bound to fail. If however they want to work closely with suppliers and try to solve the many problems that will arise, you can gain a significant advantage over the competition.
I think I may have run out of enthusiasm for the presentation, but maybe it'll come back later.
KENAT,
I'd seen mostly bad press, or at least not particularly encouraging, for inventor so was a bit surprised. Anyone care to comment?
Also found out our director doesn't know the difference between a CAD model and a CAD drawing. Awesome.
KENAT,
KENAT,
Matt Lorono
Silicon Valley, CA
I think the phone call told my boss enough that he sees that with current technology and our place in the supply chain etc. hybrid model & drawing is probably as far as we can reasonably go.
It's just my ego that smarts from him not accepting it from me when we first spoke about it.
KENAT,
