Beam Splice with Thermal Break
I have a situation where a steel beam is cantilevering from inside to outside, and the architect wants a thermal break. So, I was thinking of creating a splice at the exterior wall with endplates on each side, a material such as a structural expansion bearing between the plates, and bolting them together to create a bolted moment connection. The shear would have to be transferred by bending in the bolts across the width of the gap between plates., but the loads aren't all that great.
Any thoughts??
Any thoughts??
RE: Beam Splice with Thermal Break
http://www
VB
Check out VB's link to Schoek.
Thanks for the link. They make some great products!
