Bolt Punching Shear in Steel
Does anybody have any references for calculating the capacity punching shear/pull-through of a bolt in a relatively thin steel plate?  I remember performing the calculation a few years ago but can't seem to remember my source.
Thanks.
RE: Bolt Punching Shear in Steel
AISC has an equation for pull-out of a bolt thru a HSS Section. You could probably use the same equation.
Rn = 0.85(dw)(t)(Fu)
dw = diameter of part in contact with the inner surface of HSS
t = wall thickness
F.S = 3.00
You need to look in the AISI (American Iron and Steel Institute) Cold Formed Steel Design Manual.
