I need an adequate flowmeter for 12" Ductile Iron potable water pipe
I am currently working on a water audit in which we have tried (somewhat unsuccessfully) to log flow through a 12" DI pipe. We have only tried a turbine insertion meter which has worked on and off, it has stretches where it logs data just fine for a couple of weeks, maybe a month, but eventually it starts to produce very irregular data graphs (long periods of zero flow logged when the pipe has not been empty followed by some flow). We have replaced the turbine on many occasions, and also switched other insertion meters (same model) from other areas to the problematic location with little or no success in stopping the problem. Can anybody give me any tips on selecting a proper water meter for this pipe (I just need instantaneous flow and a datalogger)? Preferably an insertion type meter. Thanks in advance.
RE: I need an adequate flowmeter for 12" Ductile Iron potable water pipe
http://
The former Controlatron, now Siemens brand ultrasonic works great on DI pipe. It straps on the outside and does a great job. It has an internal memory for data logging.
ht
