Serrated Steel Grating
Can anyone please advise the minimum standard serration notching that would be required to hold a 300 lb. person with the grating angled from 9 up to 15 degrees? Gratings designations needed are W-19-4, W-26-4 and W-25-4 with bearing bar thicknesses of 1/8" & 3/16" as well as minimum standard cross bar sizes. Thank you very much.
RE: Serrated Steel Grating
