Split solids in ProE
Is there a way to split a solid part or assembly into two halves in ProE.
For e.g. if I have an assembly with 2 parts. I want to bisect the assembly into two halves creating 4 different parts. Is it possible to do this in ProE ?
Any suggestion/advice to do this ?
Thanks in advance,
SS
Thanks in advance,
SS
RE: Split solids in ProE
You could split the part using instances of a generic where each instance has a cut operation to remove half of the part.
