How pipe dia determine ?
How pipe dia determine to suction the certain density material from any certain distance ? How can we know the required MASS OF AIR and SUCTION AIR PRESSOR for the same ?
Bhavin
Bhavin
RE: How pipe dia determine ?
If the pipe is 6" pipe then one pipe diameter is 6"
If you are working in metric units then 150 mm pipe one diameter is 150.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
