Triangular lattice guyed tower-Torsion?
Pals
How is torsion taken into account for in these towers?
What difference would it make were 3 sets of guys not spaced 120 degrees apart, say 135,100 and  125 degrees apart
respects
IJR
RE: Triangular lattice guyed tower-Torsion?
If you have a dish at the top or anywhere along the height, the localized torsion produced by wind loads on the dish has to be accommodated; however, I have generally not looked at global torsion of the tower in analysis, since the guy cables have equilaterally corresponded to the vertices of the triangle.  If you change the angle of the guys, you would have to consider torsion in the global sense for the tower.
