Zero Stiffness Warning
Hi!!!!
I'm getting a warning in Staad Pro saying something like Zero stiffness..
What's the best way to get rid of it???
Any suggestions...
Any suggestions...
RE: Zero Stiffness Warning
It's working fine!!!
But why is that error arising??
What is the logic behind using that SET PRINT 1???
It'd be much helpful if u could furnish the reason for that...
Arun.
It is not an error. It is rather more a note or FYI. Zero rows and zero columns (at a joint) in the global stiffness matrix can occur when trusses or releases or tension/compression-only are used by some or all of the members at a joint. The zeroes are almost always harmless but the message is printed in case the engineer is not expecting zeroes. It is possible that a wind load/floor load will generate a load at a zero dof and in effect be lost but that is rare. The Print Static Check will be out of balance in such a case.
