Steam Jacketted lines for Molten Sulphur
What is the acceptable length of the Steam jacketted lines for molten sulphur with one steam inlet and outlet to the jacket. The jacketting steam pressure is 3.5 bar. It is being asked to have single length of 20 metres with one steam inlet and outlet . Is there is any standard for the designing of the Jacketted lines? My concern is on the Maintenance aspects ( for dismantling , repair in case of leaks in the jacket etc). Pl advise.
RE: Steam Jacketted lines for Molten Sulphur
There are construction, transportation and installation limitations also. 20 meters is too long.
Since jacketed pipe must be shop fabricated in segments, I suggest that an 8-10 meter maximum length may be more practical
Which MBA superstar insisted on a 20 m length and what is his basis for the 20 m ?
You are, of course, aware that segments can be "jumpered" together for steam distribution and condensate collection........right ?...?????
Is this the first jacketed piping system that you have ever been involved with ?
-MJC
http://
Keep your distance between traps from being too long, and be certain traps in this service are on an inspection program for routine checks if possible.
I am willing to bet that the maximum spool piece length for jacketed pipe is not too much different that the max for lined pipe...
Around 20 feet....
http://www.resistoflex.com/minspool.asp
I also suggest that, due to condensate drainage issues, 20 ft may be too high for jacketed spools.
Sengutt....in what country will be this system be located..??
You state: "The Process dept requires technical justification for not having it for 20 metres"
BTW, It's always great working for opinionated, arrogant people with little or no technical background....isn't it ??
-MJC
