Properties Problem
Properties Problem
The properties tab is missing when I go to a 2008 part file's properties in explorer. I can see custom properties of SW 2006 files, but not properties of 2008 files. Is there a chack box that I have overlooked? I have no idea where to start looking.
RE: Properties Problem
Are the files originally SW2006 files that you are now using in SW2008?
Have the files been saved as SW2008 versions?
Do the files have custom properties assigned in SW when you go to File > Properties in SW.
In Windows Explorer > RMB > Properties > Custom Tab
In SW Explorer make sure to select the file in the File Explorer pane on the left, then select the Properties tab on the top right pane.
Cheers,
Anna Wood
SW2008 SP5.0, Windows Vista SP1
IBM ThinkPad T61p, T7800, FX570M, 4 gigs of RAM
http://www.solidmuse.com
http://www.phxswug.com
