UW 16.1 question
UW 16.1 question
Hi All,
I would like to design a Category D weld with weld details per Fig UW-16.1(a). However, this figure does not give me adequate joint preparation details. Infact, the other joint types on this figure also do not give this information. If this not of importance? Can I use any suitable joint preparation? Is it ok to simply compute the resultant stresses based off of the Internal pressure in the nozzle and a stress area based off of the dimension tc shown?
Thanks in advance!
Thanks in advance!
RE: UW 16.1 question
what details is it missing??
thanks
Can I use tc as a throat thickness and use the regular stress = force/area calculation to validate my weld?
That's a good question, and perhaps someone on this forum has the answer.
I would follow the calculations as given in UW-16(b) and then perhaps doublecheck with your method of s = f/a.
ug-45(c)
uw-15(c)
ug-41(b)(1)
should be reviewed
