"Putting Material"? that complies with AISC specs.
does anyone have any info on this? What material would you assume that they are calling out? a lead sheet? neoprene? epoxy? Please advise?  I cannot find and reference for this.
RE: "Putting Material"? that complies with AISC specs.
AstroTurf ?
Rye Grass ?
Poa Annua ?
Bermuda ?
Callaway?
Topflite?
Tiger?
Just what is the application for which this is called out for?!  That might provide some insight into what is really requested.
Qshake
pipe
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Bridge grating anchor bolt replacement.
Is this anchor bolt in concrete? Or is the grating tied down to a girder?
If it's concrete, chances are that the specifier wants to fill the annular void between the bolt and drilled hole.  An epoxy grout type material should be what they're looking for.
Qshake
pipe
