Best Alloy for SS mixer blades?
Hi:
Looking for the best combo of hardness and corrosion resistance in stainless steel.
We like 17-4PH for hardness and fab reasons,
We like AL6XN for corrosion, but it's too soft.
We'd also like to avoid elaborate heat treat or welding procedures.
Colin Caissie
UET Mixers
Colin Caissie
UET Mixers
RE: Best Alloy for SS mixer blades?
There is a tremendous difference in corrosion resistance between those alloys. If you need something close to AL-6XN then you should look into a super-duplex alloy (2507, Zeron 100, Feralium 255). These will be stronger than AL-6XN and have similar corrosion resistance.
Plymouth Tube
(C276 is also known as Hastelloy C)
