SW prevents macro from creating overlapping points
Run the code below with a sketch in the X-Y plane open. Select all of the points and note how many were created. Now, delete the points, zoom in a little, and run the macro again. Note that the macro creates many more points this time.
SW prevents the macro from creating points that overlap one another. I am assuming that this involves a setting. Is there any way I can turn off this setting? Thanks.
Option Explicit
Dim swApp As SldWorks.SldWorks
Dim swDoc As SldWorks.ModelDoc2
Sub main()
Dim r As Single
Dim x As Single
Dim y As Single
Dim t As Single
Set swApp = Application.SldWorks
Set swDoc = swApp.ActiveDoc
Dim skPoint As Object
r = 0.01
For t = 0 To 6.28318 Step 0.01
    x = r * Cos(t)
    y = r * Sin(t)
    Set skPoint = swDoc.SketchManager.CreatePoint(x, y, 0#)
Next t
End Sub
RE: SW prevents macro from creating overlapping points
i don't think there is any way to get SW to place two points at the same coordinate in the same sketch. for what reason do you need two points at the same coordinate?
rfus
There is a setting that prevents SW from merging two close sketch points.  I can't remember what it is at the moment.
I should also mention that you should turn off snapping to get the best results.
rfus, at no time is the macro attempting to place 2 points at the same coordinate.
Found it!
ModelDoc2::SetAddToDB
Set to TRUE to turn off snapping.
Works beautifully... many thanks!
