ASTM A53 GR B Sch-40 8" Dia ERW Pipeline Testing& Inspection Criteria
Since no response from other Forum, May be this is more appropriate place!
Dear All Hello/Good Evening,
Kindly oblige through guidance on the %age sampling for Inspection/Testing for captioned subject Pipeline of Chinese or Korean Origin
Also guide with preferable technique to be employed i.e.
1)Ultrasonic
2)Radiography
3)Electromagnetic(Eddy Current
5)Any other tests needed for this "longitudinal" Seam Welded Pipe Type.
Pipeline involved is around 6100 Rft for a refinery piping Project.
Early Help with applicable Code/Standard?good Engineering Practice reference,if any will be highly appreciated.
Best Regards
Qalander(Chem)
RE: ASTM A53 GR B Sch-40 8" Dia ERW Pipeline Testing& Inspection Criteria
from China?
i would ask for chemical and physical tests from each heat of pipe
100% radigraphy of each random length
Dear metengr,unlesyd,gr2vessels,CodeJackal and others.
Can any one else come forward with further Comments/suggestions,If any!
Thanks in advance.
Best Regards
Qalander(Chem)
First.... I suggest that you post this question on the "Piping and Fluid Mechanics forum"....you will get a much better grade of responses.
Second....Who is doing the mechanical engineering for the project and which international standards are being followed? It is these standards that will determine the degree of NDE for each type of pipe.
Third.... Where are your piping line specifications ? Where are your design drawings ? Are you going to purchase 6100 ft of the same type of pipe and then try to use it in the project ?
What kind of "refinery project" is this...!!??
-MJC
Thanks for Response ,Dear MJC indeed!
The original post was on your suggested forum .Although not very much responded.
Best Regards
Qalander(Chem)
Dear Sjones Thanks for informative links;Hope these should be helpful.
I shall be back on this.
Best Regards
Qalander(Chem)
Having been involved in the manufacture and inspection of ERW pipe, I would advise UT and Magnetic Flux Leakage testing to confirm seam soundness and hydrotesting to confirm pipe soundness. Noting some of the recent failures of steel materials attributable to nonmetallic inclusion counts common in 1960's and 1970's steel manufacturing, I would also advise wet flourescent magnetic particle testing of the weld seam; inclusions can be squeezed to the surface creating crack-like flaws.
Before going too far on inspection, what are the service conditions; i.e., temperature, pressure and fluid?
Probably
1)Refinery Firewater
1)At or around near ambient temperature
(Under shade max.53 Celcius)
2)Pressure at or around 12.0 Barg(usual max.)
Best Regards
Qalander(Chem)
With that small quantity of pipe, I doubt you will be able to get very picky.  I would imagine that you'll have to choose from what's on the shelf, so you will probably just have an opportunity to select from whatever standard mill tested pipe happens to be in stock, unless you get very lucky.
If you're concerned about what is available, go inspect it at the pipe yard and perhaps later plan on doing a longer duration hydro.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
A hydrotest of the underground installation in accordance with NFPA 24 is all that I would recommend.
the AS-53E A OR B PIPE IS ALREADY CERTIFIED FOR UT OR EC 100% that shoud satisfy your requirement.
IN API IS NOT A REQUIREMENT.
