Guidance value for HH and HK grade castings
I shall be thankful,if some of the members familiar with sourcing of parts provide a guidance value for HH and HK grade cooler plate castings in cement mills.
It has been more than a year since i produced such parts,hence my request.
Thanks in anticipation.
I have not failed. I've just found 10,000 ways that won't work." — Thomas Edison
_____________________________________
RE: Guidance value for HH and HK grade castings
Not sure exactly what you are looking for, but if you want a foundry to produce your castings there are many including; Trident Alloys (MA), Atlas Foundry (WA), Standard Alloys (TX), Stainless Engineering (WI) and many more.   If you can be more specific with your request, I might be able to help.
it's been years, ok, decades since I was involved in cooler grates and their specs but from what I remember,  if you need HH or HK grates,  you ( or they) are not operating the cooler correctly
macmil,That is an interesting observation you are making. Please explain your reason . For over 2 decades I have been making cooler grates in these alloys and supplying to various plants .
