A 333 minimum specified temperature
I'm new to the field and need to find out the minimum specified temperature for A 333 pipe.
Thank you.
Thank you.
RE: A 333 minimum specified temperature
for ASME B 31.3 the minimum temp without impact test is -50°F.
S
Corrosion Prevention & Corrosion Control
