Optimum Wall thickness selection
Could you help me to decide which wall thickness is the more appropriate from different point of view (economic, comercial availability, flexibility) for a pipezise 30", calculated thck 0.100". Any one knows prices for pipes, i would like to evaluate cost to make a decision.
Thanks in advance
Thanks in advance
RE: Optimum Wall thickness selection
David
The question on pipe prices comes up periodically. You might do a Google search on the forum to find one of the past threads.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
P.S. That 30/0.1 D/t ratio is too high anyway.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
If you calculate 0.1 inch wall thickness is needed and you only need a few joints of pipe, you'll probably be forced by economics to order 0.250" wall off the shelf, or the next thicker wall, etc. until you find something that meets your delivery schedule requirements.
