tube fittings & tube manufacturers
I have a few questions,
1. what sort of flexible "tube to tube" fitting can be used and will with stand 140degC steam at about 3barg
tube spec => out dia 25mm, wt 1mm
2. what sort of fittings are there (apart from welding & swage joints) for fitting a tube to it's manifold operating with the conditions 140degC steam at about 3barg
(picture of tube & manifold/header attached)
3. does anyone have contact details of tube manufacturers in the uk?
Thanks for the anticipated responds
