E values for masonry wall panels under lateral wind load
Can anyone suggest how to calculate bending moments in a non-standard brickwork panel wall under lateral loading. The code like BS 5628 give tables for standard cases and suggest that for non-standard cases with window openings Finite Element method can be used. As a panel is orthotropic ie have 2 different E-values in orthogonal directions, E-values will need to be input.
What E-values in 2 different directions can you use?
many thanks
many thanks
