REMOVING FORMWORK
REMOVING FORMWORK
Can anyone tell me how long I should wait before removing the forms and wood supports under an 8"x24" concrete beam spanning 12ft between columns for a residential terrace. I poured 3000 psi pump mix down here in South Florida? I hear after 7 days it gets 80% of its full strength but I'm getting different replies from different contractors.
RE: REMOVING FORMWORK
You could core the concrete to find its strength, since I assume you did not take test specimens for compressive strength. Don't let the concrete producer or a contractor use a "magic" Swiss Hammer on the concrete to tell you the compressive strength. It doesn't do that, even though there's a scale on it that is shown as compressive strength. It is a poor indicator of strength for a variety of reasons.
Given all that, it would be better to wait a few extra days, to assure yourself of more strength gain, assuming your beam is properly reinforced and the concrete was not modified during placement.
Ron, again educated all of us. Thanks.
