ABB disconnect Jammed
One of Our Fast grounding disconnects(ABB ELK-EB14)in our GIS was tried to be operated while it was in Lock position therfore the mechanisim inside is jammed in close position , we opened up the front cover and released the locked mechanisim and open the disconnect manually .is there any possiblity that the disconnect is still alright?(i can not see any physical damage)any way to test before taking all disconnect off ?
RE: ABB disconnect Jammed
From my point of view, you must here answer from the mnf.only.
ABB Swiss.
Best Regards.
Slava
http://www.clrwtr.com/ABB-Switches.htm
ABB's main phone number in the US is 440-585-7804. You'll have to navigate to the correct area from the menu. I believe tech support is option #4.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
