EIGEN VALUE OR RITZ VECTOR?
In an analysis of a 30 storied RCC building with moment frame and shear wall, I found that modal participation mass ratio is 54%, though I have used the number of modes 48.
What could be the reason?
What are the checks in dynamic analysis before go for design?
Can anyone send me a file of complete dynamic analysis.
thanks
shams
thanks
shams
RE: EIGEN VALUE OR RITZ VECTOR?
By code, a modal analysis should typically capture at least 90% of the building's modal mass.
---Because you have a lot of local modes in your ETABS model. This situation might be normal if you have highly non-regular structures. Increasing the number of modal shapes might be the only solution.
and though you didn't ask it in your actual question, from the title of your post ritz vectors are generally better for 3-dimensional analysis as they capture coupled modes.
---be careful about Ritz vectors, which are likely to cause significant calculation errors when high Ritz modes are used. In one case, when I increase the number of Ritz vectors from 200 to 300. Base shear tripled, although in both of two cases, modal participation mass ratio are beyound 90%
- RITZ Vector is more quick than EIGEN VALUE but at a large numbers of modes as larger than 250 modes may be become unuseful. So, you must lead to incrase manual meshing for elemens which may usally lead to acheive 90% of the building's modal mass participation.
- If there are free movement elements in the model, the model gives you low values of modal participation. So, the modal must be checked again. (see ETABS animation may help you).
- Don't define walls as membrane which leads to negative time periods and low mass participation percentages.
Best Regards,
ATOOMUS
besides, you have to use much more than 48 modes. you can use 3 modes for each storey, so that in total 90 modes
