Premature Positioning
I have an fairly small .asm file (V20) (maybe 50 parts in 5 subs) When I insert a new part or assembly, as soon as I define 1 relationship the part becomes "fully positioned", and I can't define further relationships, the dreaded "conflict" message pops up. This doesn't happen in other files, tho I recall it happening before long ago - can't remember how I fixed it (if I did)
RE: Premature Positioning
Does this happen when you insert any part, or just one in particular?
Start by checking for any existing failed or conflicting  relationships in the assembly.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Happens with any part. I did have some links that wanted updating, when I did that it helped, in that now I can add more relationships even though the part is still "fully positioned" after the first. I could live with this except some of the parts are doors that I want to rotate easily. This problem does not happen in other files.
I've seen this problem several times in the past, but never been able to come up with a definite reason for it happening.
The only thing I can suggest is to check each part model and sub-asssembly for errors.
bc.
Quadro FX4600.
I think it's a bug. did you put the latest Service Pack ?
Fred
