Weldment GD&T Guidance
We are in the process of starting up GD&T implementation at my company. I am curious as to how detailed we should be as we begin using GD&T on large weldments. There are lots of small blocks welded onto plates as well as mating surfaces with bolt holes, welded on fabricated brackets with peviously machined details. What level of GD&T would you who have experience reccommend? Should we use GD&T on the drawings of simple blocks details? Some are no more than a rectangular block, some are a block with one or two tapped holes. Should we only use it on critical mating surfaces? Should we do all mating details? Are there some guidlines?
I arrived here last year, and am trying to bring the company into the twentieth century. We have lots of poor drawings and every assembler has a grinder.
RE: Weldment GD&T Guidance
The guideline to follow is ASME Y14.5M-1994.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
I believe the application of GD and T, (Y14.5) on weldment
drawings should be approached with caution. If interchangeability is an issue, then the application is more valid. Otherwise it would seem of limited value on a 'typical' weldment drawing.
Chris
ctopher's blog
SolidWorks Legion
Thanks for your input. Unfortunately, at this time the company does not own a copy of ASME Y-14.5.
I should be able to get the new standard soon, so I am waiting for that. In the mean time, I've been using a very good textbook by James Meadows to bring myself up to date, in preparation for teaching the design and drafting staff here. Meadows does not, however address weldments in this book. Should weld-on details be located using positional tolerance, or is it permissible to use toleranced dimensions? When I have two opposing planes, one of which is a datum and the other a face of a weld-on block, is that a feature of size? What does ASME Y-14.5 Have to say on the subject?
A weldment is an inseparable assembly. The specification of the assembly typically details the type of (weld, bond, press, over-mold, rivet, etc.), its location, its boundaries "if critical", and its properties "integrity, performance criteria, etc." The specification also typically includes some obvious specifications for measurement of alignment and location of one detail to another. Individual details are typically fully dimensioned and toleranced on their separate specifications and are assumed to retain that dimensional integrity throughout the assembly process.
There is an ASME specification for inseparable assemblies but I cannot remember its number and I don't want to look for it in my retirement stash. I read it quite a while ago and recall IMO that it was very superficial and not much help in constraining the outcome of inseparable assembly processes. Being the arbiter of numerous quality disputes concerning inseparable assemblies in my roles as a quality engineer, STA engineer, and CAD GD&T strategist... I have consistently recommended to the designers and design engineers that they specify the functionally critical attributes on the inseparable assembly in terms of size, form, orientation, and location. There has always been considerable resistance to doing this because assemblers do not want to check stuff that they did not produce and they do not want to be held accountable for pass-thru discrepancies attributable to the up-stream detail producer.
The bottom line is that inseparable assembly specifications are often jam-packed with assumptions that the assembly process cannot or will not affect or change the feature characteristics specified on the sub-assembly specifications. In my experience however with numerous powertrain components it often is not true. Heat and force do things to various material shapes that may be unpredictable and when that variation goes undetected the customer ends up as the assembly inspector.
Since the practice of detailing functionally critical attributes on inseparable assemblies will likely meet with considerable opposition from purchasing, manufacturing, and quality in terms of time and cost for the scrutiny... I would moderate the assembly detail specifications to those that are absolutely critical to function. Many will claim that this practice is prohibited because it is dual-dimensioning but it is not because when those details are inseparably assembled it is a new part.
Paul
The standard says "An inseperable assembly drawing fully defineds the end product as assembled" as such any required dimensions & their associated tolerances are needed. Per 14.5 the preffered way of doing this for many situations is to use some kind of GD&T.
So, use GD&T on your weldments where it is appropriate.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
Your input has been most helpful. It looks like we will settle on a hybrid approach, using GD&T for most functional features, but allowing some linear postional dimensions, if they do not affect fit or function.For now we will concentrate on modifying existing drawings in areas where we have experienced assembly fit-up problems, using GD&T to clarify fabrication and machining, inspection expectations.
We can also address new drawings as they occur.
Thanks Again,
John J
