how to convert imported STEP solid to a real solid?
I have a large STEP file to import into Cadkey 19. It comes in fine 35+meg, but when I cut it to take out a part to make a STL model, it is thin surfaces. I converted the whole thing to surfaces, and created surfaces where the cut planes are but it will not reconvert to a real solid. (Invalid model)
I tried reducing tolerances, but that did not work. The STEP file weas created out of CATIA. I need to subtract some cylinders for countersinks and bolt holes. I am stuck.
RE: how to convert imported STEP solid to a real solid?
