Wastewater Concrete Tank Coating
Any thoughts or suggestions on coating an aging concrete tank that is showing signs of leakage? These are concrete tanks that hold "industrial waste", which basically means that the water is very grease and oil laden.
My thought is to drain and sandblast the tank and paint on some form of coating to seal the cracks. My concern is that the coating will adhere.
Will sandblasting penetrate deep enough to remove the oils?
Any other ideas?
Any other ideas?
RE: Wastewater Concrete Tank Coating
http
http
