Identifying 'bad' element?
Hi all,
I have an analysis running which seems to be getting stuck on 1 particular element.  The output indicates "1  U-P ELEMENTS DO NOT SATISFY THE VOLUMETRIC COMPATIBILITY"
I am not so much concerned about the message because I encounter it all the time with hyperelastics.  However, is there a way to identify which element it is?  I could then go back and check it or change the material to a linear model for just one element.
RE: Identifying 'bad' element?
Hi
Use the NLDIAG to set the criteria, after solving use the NLDPOST to get these elements in a component.
Unfortunately I am running a distributed analysis which does not support the NLDIAG feature.  It's a shame.
