Boeing document D6-24957
Hello All,
I am after the Boeing book D6-24957 "Design for durability and damage tolerance" i believe is the title. I used to own a copy but cannot find it anywhere!
Anyone knows where I can get my hands on a copy? Maybe even download? I just don't deal with Boeing anymore and lost my contact their.
RE: Boeing document D6-24957
Garland E. Borowski, PE
Engineering Manager
Star Aviation
I think that d6-24957 is the newer or updated version of d6-24956...
Anyway, do you have a contact at Boeing I could use to get documentation.
Try e-Mule.
Search results were 0 for me.
There's two docs - one thru 1980 and one thru 1988. As I said, not the most current, but at least something for your library.
While you're at it, the Airbus doc will come up with the noted search criteria.
just made the search and found couple of interesting docs. will wait till it's in the cpu.
Unfortunately i still didn't find the original Boeing book D6-24957 "Design for durability and damage tolerance" i am looking for.
They come up on my search using the noted criteria. 2 .pdf files, one 43Mb and the other 17 Mb. Both D6-24957.
I know really crazy... does it make a difference on which server you are connected to when using emule? if so can you give me your connection details. I am currently connected on sharing kingdom 2.
still no luck when plugging in fating and setting any and automatic
i can only see one file. hopefully its the right one @ 17mb.
well let you know once its done...
I can tell you that 6 is more the experimental data and 7 is the analytical way and formulas. What is in 8?
I just found them using a "search".
Look at previous posts i just used what Gbor suggested.
Well, two I found were not on the www.
Try e-Mule."
"Craig1983 (Aeronautics) 9 Mar 09 9:11
bf109g what search criteria did you use on e-Mule?
Search results were 0 for me."
"bf109g (Aerospace) 9 Mar 09 9:35
Try "fatigue" with Type set to "Any" and Method set to "Automatic."
While you're at it, the Airbus doc will come up with the noted search criteria."
"Craig1983 (Aeronautics) 9 Mar 09 10:52
thanks,
just made the search and found couple of interesting docs. will wait till it's in the cpu."
sure sounds like you're using emule ?
